FABTECH FTS24095 2007-2012 JEEP WRANGLER JK 2 DOOR WITH SHOCKS 3 IN. SUSPENSION KIT
This system provides increased ride height for oversized tires without stepping into a full link arm system. The fabtech standard coil springs will provide additional performance to the suspension for both on and offroad use. System can be upgraded in the future with fabtech’s short arm links or long arm conversion.
Features- Standard coil springs front & rear
- Track bar bracket rear
- Sway bar links front
- Brake line drop bracket rear
- E brake bracket
- Urethane bump stops front
- Bump stop brackets rear
- Twin tube hydraulic construction
Specifications- Color: Black & Silver
- Material: Steel & Aluminium
- OD of Body: 0.56
- OD of Piston: 1.37
- Year: 2007-2012
- Make: Jeep
- Model: Wrangler
- Weight: 89 lbs
Price: 1293.57
