AIRBAGIT DOOR-SUI-20 SUICIDE DOOR X2 BILLET POLISHED HINGES ONLY FOR BOTH SIDE
Suicide Door x2 Billet Polished Hinges only for both sides. Hardware included.
- Mount Suicide door safety unit on door.
- You will need to drill mounting holes and hole for locking pin in door and hole in door jamp for locking pin to go through.
- Item Weight - 20 lbs.
Each Set Contains- 2 Latches.
- 2 Strikers.
- 6 Bolts for Latches.
- 6 Nuts for latch bolts.
- 6 Washers for latch bolts.
- 2 Large striker washers.
- 2 nuts for strikers.
Price: 721.62
